TwinTurbo.NET: Nissan 300ZX forum - Easiest test: At about 60 mph in 5th, put gas pedal
zellamay
on April 26, 2012 at 12:42 PM
Clutch gone?
posted by HK'S Z
on April 26, 2012 at 10:35 AM
on the floor. Keep it there to 90 or so. If your clutch is slipping, it will do it then. Your description sounds like you've sort of done that already, and it's slipping.
Clutch gone?
HK'S Z
10:35:55 04/26/12
Do this
Draker (Eugene, OR)
11:25:11 04/26/12
Thanks Craig! I will try that. (n/m)
HK'S Z
11:41:12 04/26/12
Easiest test: At about 60 mph in 5th, put gas pedal -
zellamay
12:42:28 04/26/12
Zellamay - Yep, I had a car with a bad clutch before
HK'S Z
13:01:07 04/26/12
Re: Clutch gone?
300ZMang
15:14:27 04/26/12
300ZMang - Been testing for boost leaks, counldn't
HK'S Z
10:49:05 04/27/12
Did you adjust the clutch travel?
Chickan
18:18:04 04/26/12
Chickan - Yes I did. It starts engaging about 3/4 of an
HK'S Z
10:29:41 04/27/12
